David, FWIW, I think you're close to being spot on - at least the 11.5:1 AFR at WOT is what most Supra guys run for safety's sake. You could increase the AFR a bit for cruising for economy's sake.
Only monitoring the plugs and EGT's could tell you otherwise. BTW, How much timing are you running?
Here's an excerpt from a standalone ECU manual with suggestions for initial AFR setups. Note the WOT AFR's are somewhat higher than you're running, but it all depends on how brave you are, and how much confidence you have in your setup.
