88sogreatv8
I know this is a forum for the uz family, but im stumped atm on an over heating issue. I have a 2017 tundra 5.7L , bought new maintained well having an issue with it overheating. At first it was very intermittent and random. I initatialy thought it was a sensor issue so , i swapped the temp sensor with a oem sensor from toyota.
The issue was still there, so i swapped the radiator cap , also OEM. Issue was still there. So i changed the thermostat. This one i used a murry from O'reilly. Now the issue seems worse. The temp will start to climb all the way as high normally as 250 degrees , then just as quick at climbed it falls back to normal. I dont trust the aftermarket thermostat , so i ordered a OEM one to test the waters , so we will see.
However, my opinion is it will not fix it even with a stock thermostat. Has anyone had this issue? Im going to check the clutch fan to see if it is going out. It did seem loud this winter, but maybe im just paranoid. I also checked to see if the water pump is leaking. It looks dry. I havnt found any common TSB's on overheating, or recalls .
If anyone has and information , or has experienced anything like this the help would be much appreciated
