2UZFE Pistons/Rods Combo
I got a customer ordered the Pistons/Rods Combo. We installed and tested before shipping everything clear and rotate very well. I also included a set of Clevite rod bearings as a gift too. This customer will be very happy. If you look closely, offset is there too. They are direct bolt on the stock 2uzfe crank. This customer is only looking for about 500-600 hp. Therefore this combo is more then enough strength to handle it. We are the first to offer this combo in the Lexus-Toyota V8 community.
Here is a picture of the rod rotation in the block:
attachment.php
Here is a picture of 1, 2, 3 and H Beam rod. As you can see why the 2 and 3uzfe rods are very skinny.
Legend:From left to right:1uz, 2uz, 3uz, H-Beam
Hello Andrew,
Yes, pistons face are made according to the customer's requirement. VVti or Non-VVTi will have different face. So to answer your question its yes, the 2uz pistons are ordered with 2uzfe combustion chamber. Even with VVTi 1uzfe "post 98" will have different combustion chamber. Below picture is a stock 2uzfe piston/rod and the other is the 1uzfe "non-VVTi" low compression piston with 1uzfe chamber. The second picture is the forged piston designed by Ross for the 2uzfe chamber. The last picture is my friend Wayne's low compression 2uzfe pistons.
