2006 Ford GT Dyno
Need I say more?
To get some technical specs on it:
All the pictures I see show it to be dry sump oiling from the factory.
Engine Type: DOHC, 4 valves per cylinder, supercharged V-8
Engine Displacement (L): 5.4
Bore/Stroke (mm): 90.2x105.8
Displacement (cu in/cc): 330/5409
Compression Ratio (in/mm): 8.4:1
Material: All Aluminum
Horsepower : 550
Torque @ RPM (lb ft): 500@4,500
Horsepower Specific Output (hp/liter): 92.6
Torque Specific Output (lb ft/liter): 92.6
Recommended Fuel: 91 octane (premium)
Fuel System: Sequential multi-port electronic fuel injection -(SEFI) with dual injectors per cylinder
Oil Capacity with Filter (quarts): 10
Usable Fuel Capacity (gal): 18
Is that the GT500 with a few mods? Need more info...
Those GT500 are reasonably priced and reasonably fast for sure...
I think I read that the GT500 can over take a standard new Vette...If that is the case it is very fast...
Fairly sure we're talking about the actual Ford GT "supercar". That kinda blows the "reasonably priced" part out the window. The suggested retail is in the neighborhood of 150K.
A little more then I care to spend on a machine with wheels... I got $50 bucks so what fast Ford can I buy with that?
I've seen the GT40 first hand and they look awesome...
