Cribb Notes
Cribb sports another 'mull-it'........:smokin:
Steel crank - Forged Steel crank ......... steel being operative 'street slang' for Forged, Toyota underplays the 2 UZ and the 2 UR in print - but who chose the Uzzie-2 to go racing with - this
http://tinyurl.com/2sdl4u 'Truck' engine ?
Toyota uses 'Compacted Graphite Iron' in their Iron blocks - NASCAR block included - not boiler scrap iron.
Anyone remember the 4 cam HEMI project MoPar had
back in the late 60s ?
David's .jpgs of the 2 UZ block - with belt covers off, is a mirror image of that engine - MoPar Fans begged to have produced.
Harmonics & Vibration ruled out production - fractured the cam bossings.
Claims that development and materials upgrade would have brought production costs of the engine into astronomical was reason given for 'mothballing' the design.
Enter 2 UZ FE:
So here's the MoPar 'Dream' Engine - with an oiling system that doesn't require a belt driven pump - wet sump - to survive, as does the Ford 5.4,
doesn't have 'hot spots' - or 'heat problems' in the heads, as does the Ford DOHC 5.4 and whose block is 20+ lbs. lighter than the Ford 5.4 NVH - with the bore of the Cobra Aluminum Race Block - and is available in salvage yards for under two grand......what's with the groaning about 80lbs. over a 1 UZ weight?
Move the battery to the Trunk ?
I'm tempted to go 'bone stock' - as upgrades to my LS430 A761E six speed are a must - trans then good to 9.99sec bracket.
But the valve train can be made to handle 9,000 rpm with $300.00 in springs
and the oiling system has zero complaints - totally amazing - rods and pistons are going in before fitment of the engine to the car - a small price to pay to begin to awaken this sleeping giant.
I want this thing to 'sing' the 'R's like 'Ella'.
Turbo ? ....... a good single 'driver snail' can be had for $600.00:
www.mjmturbo.com
yet most of Turbo costs are the electronic controls - to be able then to 'Dial -a- Boost' at will.
But Turbo isn't in this first hand of cards - just rods / pistons / ARP suds,
then Option 'T' is on the Table with this jewel.
Car shows - some weekender's to Rockport Mass. and Jersey Shore rather than wheelie bars and 10mpg tells me a pump gas build plan is required.
Compared to what you'd need to put on your average American V8,
to 'get it right' - roller rockers , pushrods, girdle, guide plates, intake, carb/EFi, roller camshaft kit, rod/piston upgrade, oil system mods, upgraded pump, cooling system upgrades, block mods, harmonic balancer upgrade, valve seat mashing spring pressures - just the roller cam kit alone is over $1,200.00 - and you have what........ ?
This Uzzie-2 engine sounds 'Awesome' - revs 'Awesome' - looks 'Awesome' in stock form and with the Tech reads available on this 'Awesome' Forum, I am going to have that 'Dream' engine I ogle'd as a kid on the sidelines those many lifetimes ago - and not go broke doing it.
