cjsupra90
well if its off 1 or 2 teeth on the cams, then they are out either 7.5 deg's or 15 deg's respectively, which translates into either 15 deg's or 30 deg's at the crank. if they are off in a retarded direction, then that would explain the no run and back fire issues assuming that the backfire was in the exhaust and not the intake and that both cams are off in the same direction.
