1UZFE into Ford Sierra XR4x4
jebus!!! now that's what you call DIY....
if i had half as much knowledge and skill as you, i'd already have a backyard full of "toys"....
great work!!! keep it up, and btw, loving the pictures... nice, big and bright!!!
R-Jay:
It's not so much about skills as it's daring to do something.
What it comes down to is measure once, then measure again
and then cut.......
I have run into a problem, I don't have enogh space for the driver
side turbo. The picture shows where the steering shaft from the
bulkhead to the steering rack is located. This combined with the 4x4
crossmember means that there is not enough space to fit a turbo there
as well as a decent exhaust manifold. I can always do a log manifold
but i'd rather not do that as they su*k.
I have to have a think what to do..:-(
The 1UZFE engine is finally in the car. Everything is done, sump, engine
mounts and plate between engine and gearbox.
this has to be the biggest engineering feat i've seen since Rad Hadfields 55 chev with a merlin 27 litre V12 supercharged engine intalled.
i can't wait till you finish it. should be well worth all the work.
congratulations on you're effeort and ability so far.
dean, ps i'm considering a simple(by comparasin) ford XF falcon conversion
Hi just wondering if theres any progress, i need a bit of inspiration to continue with the ford falcon Reshell.
thanks Dean
deankdx:
It's still in the workshop, I have not done much to it since February as I have been busy with work and other projects. I hope to get cracking on it in a month or so when the last remaining project is done.
Oh my friggin god.
Thats simply amazing...
Any estimate on how much time you have spent on it so far?
This rivals the 4WD twin turbo 4WD 70's Celica (TA22) being built at the moment!
i don't think you'll need a log manifold looking at that - but it will be tight.
i'm dying to see the end result. keep up the good work dude.
And here i was thinking aa Aussie falcon with a 1UZ would be original, there is some seriously talented people on here.
i personally would not even have thought this would be possible hence would not even have dreamed about doing a conversion such as this.
i can not congratulate people enough for their talent in overcoming the engineering feats such as these.
cant wait till they are used for the purpose in which they were designed.
thanks heaps Dean
MWP:
To much !
Honestly, I don't know. The bodyshell and the suspention I have been working on and off on for 4 years and lets not
talk about the engines...
When I started the project the plan was to turbocharge a V6 2.9l Ford Scorpio 24v engine but when I began
collecting information I soon found out it was an engine not suited for what I planned to do, so I had to change the
plan. Then I was back to a 2.0 Cosworth 16v turbo engine, but to get reliable serious power from those it would
cost an arm and a leg as good parts for those is getting scarce.
Then I started digging for alternatives, and the 1UZFE I had a look at 5 or 6 years ago but I did not have a car
suitable to fit one then. I knew it would be difficult, but I figured I'd give it a go and ordered an engine from Adelaide
J*p Dismantlers. When I ordered the engine I did not know if I would be able to use the 4x4 system, I did not know if
the block skirt would be to deep and I would not be able to fit the sump with the front diff to it. As it is it is marginal,
with the Gp. N front diff I have I have to grind a fair bit of the sump flange on the engine to get it to fit.
I do have some concerns about the sump, I think it will be strong enough to hold the diff in place, the lack of aluminium
above the diff might be a problem but it remains to be seen.
You had the engine sent from Adelaide to Norway??
Makes me glad i live in Adelaide as ill be looking for a 1UZ soon :)
As for the sump strength... is there any way to make an extra support bracket from your engine mounts down to the sump?
Just thinking aloud... im sure you have thought of things like that already.
MWP:
Yes I had it shipped because it's impossible to find something like that in Norway, and Australia was the cheapest
place to get an engine. Me and a friend have 2 engines on the way, I'm getting another 1UZFE and he is getting
a 1JZGTE to his Volvo 960. They should be here in a week or so.
There is support braces on the Cosworth 4x4 diff, one from the engine mount and one from the gearbox flange.
The plan is to make new ones to suit the 1UZFE/4x4 combo but the sump must be finished first, and at the moment
I'm trying to strenghten the mounts for the front diff.
Great work. Almost makes me wish i had kept my TTUZ GT4 Celica conversion AWD...almost. Absolutely loving the sideways action instead :-)
Like jamies car though yours will be hellishly quick on the road
