1uzfe in wrangler
oliepeter
liwing in denmark i am in need for some information on boost preassure building tt on my jeep running 1uzfe tru a hilux autobox and tranny to nissan gu axels and 38" tires i need about 5 600hk if somone can help me i will be happy not many to ask the questions in denmark
op
i need to now how hig preassure i can run witout major modifications to pistons and rods i plan to use 2 nissan rbd 26 turbos and a large intercooler 800x600x90 mm 3" tubing a megasquirt ecu
question is
1max boost preassure
2 ca hw many hp
Hi OP,
Have a look at this thread:
http://lextreme.com//forums/showthread.php?t=6574
Justen is currently running 17psi boost. He uses water injection as well as intercooling. Towards the end of the thread there is a dyno graph of his 388rwkw run.
What year is your engine OP? Members have found that later versions of the 1UZFE have thinner conrods that do not last long with high boost.
hello 1ndecent i dont no what year my engine is i just bougt a front cut from a dealer that didnt care much about it maybe somone in this forum can help me i also dont now what car its from thanks op
model E-UCF11-AEPQK
frame no UCF11-OO16513
Olipeter,
Take off the plug cover and have al ook at the date on the spark plug leads.
This is usually the best indicator as to the engine's age.
hello zuffen tried the plug trick and found out that it is a 1990 model thanks for the help but i still dont no if its a toy or a lex frontcut i have the engine has a front sump and hydraulik colling fan and oilfilter mounted direcktly on the engine
op
Since you have a E-UCF11, i think the E would stand for Europe. So it should be a Lexus then. Isn't there a badge on the intake plenum?
hello both the airbag frontgrille and intake badge are missing so its not easy to see but its a right hand steer model importet from japan over an malaysian dealer about the con rods thats make it all easier i will post some pictures of the turbo install when i come a littel longer today i have recived 2 new coolers i aluminium 1 for engine oil size 400x390x45 milimeters 1for water 900x380x100 milimeters to be mounted in the rear of the car so cooling wont be aproblem
thanks for yours reply this is a big help to me because there are not much help to get in denmark on these engines :thanks: op
