I went with a TCI Outlaw. I prefer the pistol-grip and the black cover.
A mate of mine used the B&M Pro Ratchet but I didn't like the fact that I'd have to ratchet twice between Reverse and Park (since the gap is twice as far). The TCI Outlaw is not a ratchet shifter.
The way I worked out the length of the selector arm was...
- Measure the arc the selector on the gearbox takes from Park to 1st (The a341e goes through 60 degrees).
- Measure the Amount of cable pulled by the shifter from Park to 1st (The outlaw was somewhere around 50mm... I can't remember exactly)
- Using a bit of maths the formula was as follows:
Arm Length = ((360 / Selector Arc) * Cable Pull) / ( 2 * PI)
Basically I'm working out the radius of a circle, using the length of part of the circumference.
So my formula was:
Arm Length = ((360 / 60) * 50) / ( 2 * PI)
Arm Length = 47.75mm
IMPORTANT: The values I've plugged in here are from memory. MEASURE YOURS FIRST!
Andrew
