1UZF20T – what ECU fit this engine????
guyed
Hi All!!
I got 1UZ engine, Type:
1UZF 20 T
Is anyone of you guys can tel me what sort of car does it came from (it was imported from Japan)
Also, I got 2 ECU’s:
1UZFE8966-50102
And
1UZFE8966-24220
We try to get it together somehow but it look like nothing is comparing, thsoe ECUs and engine does not even looks like cousins :-(
Do you got tech papers or documents about this ECU’s?
what engines they are belong to?
Help me before getting lost in all those wirings….
Guy
[email protected]
Ecu For 1uz20t
Hi Guy,
I have a 1uz20 no letter T, and it came from a 91 soarer model uuz31 the ecu has 89661-24220 written on it and has 3 equal sized plugs on the side of the ecu, both came from a damaged but working car, hope this helps.
Best Regards
Lambo
Guyed,
Will the engine loom plug into the ECU's you have?
How many dark grey plugs does the loom have on the end of it?
Does the engine have a cooling fan run by the serpentine belt of does it have a hydraulic pump above the crank pulley driven by the belt?
Where is the oil filter? At the front of the engine of rear.
Lastly where is the bowl of the sump" Front, rear or middle.
Hi All!
Thanks for the responses
1) The Engine sump “Bowl” is in the front
2) The Oil filter is in the front too.
3) There is an oil pump in the engine… now we know what is doing there
So – what Engine model it is?
What car it belongs too?
What ECU can fit this model?
