Hi
I have a Castlemaine Rod Shop 1UZ > W58 complete conversion for sale.
I will list the parts below that are included and the Australian $$ value as purchased from CRS. All parts are as new and have only been test fitted to engine and gearbox. If you add up the cost of the package it is $1900+
No longer needed as going down different path.
$1400
Pickup in Kingsgrove or Bella Vista (SYDNEY) or will freight at buyers expense.
Jack
BH106A
SUPRA W Series 5 sp to Toyota/Lexus 1UZ-FE V8
Part# Description $
BH106A BELLHOUSING* inc, SPIGOT BUSH, PIVOT BALL $587
SB52 SPIGOT BUSH* ($45 if purchased seperately)
RINGGEAR07 RING GEAR* $150
TB09A THRUST BEARING AND CARRIER* $135
CP03 CLUTCH PLATE $160
PPLATE32 PRESSURE PLATE $240
PJB4154 SLAVE CYLINDER $105
$1400
Jack
BH106A
Passenger side hydraulic clutch set up
Part# Description $
and BOLTS
BOLT KIT*
FW44 CUSTOM FLYWHEEL* $615
