Parts 1uz, w58, stainless headers, adapter plate, clutch, etc
kildea
Boston, Massachusetts, USA
Quarter Master Rally clutch and billet flywheel, 1uz, w58, IMF headers, QA adapter
I have a bunch of parts for sale, I would rather not ship the big stuff but don't let that dissuade you ... pm me if interested but shipping will be charged separately from the prices below
- 1uz-fe engine: rebuilt heads second generation (1997) on a first generation bottom end. The only head work done beyond stock is in the exhaust ports (opened up the bowls). I have an extra sc400 crossmember if you'd like that with it - $400.
- IMF stainless headers - new - $500
- engine harness, and v2.2 megasquirt: the ms has the necessary outputs and the wiring harness is mostly there but will need to be connected to an ms relay board or a new ms connector will need to be made - all connectors necessary to run this ms are installed there though - harness/megasquirt - $250
- w58: has one of the raised short shifters that was available for a while - but no longer is - a modified 1uz bellhousing (ground off some sections that interfered with hardware), quantum auto adapter plate with small groove ground to make way for the hydraulic lines, and a tacoma output slip-yoke - w58/bellhousing/adapter plate: $500
- Flywheel/clutch/throwout bearing - This is a 7" button flywheel with Quartermaster clutch and hydraulic throwout bearing (four bolt howe-type). Both are new and unused - the clutch is the 2-disk rally clutch - $1600
the adapter mounts the trans to the bell - the bell here is for a 1uz, but the adapter plate works for any aw30/40 trans-based motor IF you have that bell (the aw30/40 auto trans has a detachable bellhousing - that's how these adapters work) ... these adapters allow mounting to any of the 1jz, 2jz, mitsu vr4, volvo white-block, 1uz, etc
Sorry for all the questions. I'm considering purchasing this. What was the Tacoma slip-yoke for? Or what purpose dose it serve? What did you have this set up in or built to be put in? Does the slip-yoke modify the output shaft on the transmission from stock or is it just something that slides onto it? What did the w58 originally come from?
