1uz vvti COP pinouts
I'm pretty sure they are similar to 3s beams and most Toyota
cop wiring
check link ecu website or motec website for info
Check P/N's against those used in other models.
Landcruiser COP's (90080-02230) look exactly the same as the Tundra COP's (90080-19027), and one of these are probably used for the VVTi engines, but the pinouts between the two are different. AMHIK.
Part number is 90919-02228, different again to what you mentioned.
I have them wired as per the link diagram, but as that is for a 2uz i think the coils are different. No spark so im double checking everything...
Found the diagram for a 2000 GS400, which should be VVTi, and here's the pinout:
Pin 1: +12 IGN
Pin2: Trigger from ECU
Pin3: ECU sensing (forgotten what Toyota calls it :))
Pin4: Earth
I don't know if your coils are the same as these, however.
