Speeedy
Hey Guys,
I'm Alex from germany and I have built a MK3 with 1UZ twin turbo.
Last weekend I was on a DynoJet first time and I want to show you my results if you are interested.
In advance here some specs:
(At this point many thanks David (Lextreme) for your help and support!!!)
- 1UZ with Ross Pistons (ceramic and teflon coated) Lextreme
- H-Beam rods with L19 ARP Bolts (Lextreme)
- ARP Head- and Main Stuts (Lextreme)
- ACL Bearings (Lextreme)
- Stock Heads and Intake (except valve springs; 2JZ-GTE valve springs)
- 550cc RC Injectors
- Stock fuel rail
- Fuelab FPR
- TIAL 50mm BOV
- Custom Manifolds (mild steel) T28
- 2x GT2871R turbos (int. Wastegate)
- Custom Turboback Exhaust (3,5")
- R154 Tranny with 1UZ Bellhousing and custom adapter
- 2JZ-GTE HKS Twin-Plate Clutch (custom hub that fit the R154 input shaft, 1UZ starter ring)
- Fuidyne radiator
- Custom Intercooler (Bell Intercooler Core 27.5"x12"x4.5")
- AEM EMS (Universal)
- MSD Blaster SS Coils (8207)
- M&W CDI
There are two runs. The first run is with 0.9 bar of boost. The second with 1.2 bar.
Fuel: 100 octan (ROZ), I think it's like your 94 octan in the USA ((ROZ+MOZ)/2).
@0.9 bar: 483 whp @ 5.3k rpm; 704Nm @ 4k rpm
@1.2 bar: 515 whp @ 6.2K rpm; 800Nm @ 4.2k rpm
I had problems with knock between 4.2k and 5.8k in the second run with 1.2 bar. But I'm not sure if it was really knock. I run the engine very rich (10-10.5 AFR) so it could be that it was rich knock. I can add a picture of the AEM log if you are interested.
Because of knock retard (8°) the result isn't what it should be. Theoretically I should see 550whp @ 5.3k @ 1.2bar without knock.
If somebody is interested in the DynoJet file (you can open it with WinPEP7) I can send it via email...
I think (or hope ) with some fine tuning and with a leaner AFR there are some hidden hp.
Maybe we can discuss my ignition map, too. (I'm very interested in your IGN Maps! )
Next year we should see some higher numbers after I upgraded the fuel system and can turn up the boost. Then with E85...
Reviews, objections and suggestions are welcome!
Alex
- Stock fuel rail
- Fuelab FPR
- TIAL 50mm BOV
- Fuidyne radiator
- M&W CDI
I think (or hope
 ) with some fine tuning and with a leaner AFR there are some hidden hp.Maybe we can discuss my ignition map, too. (I'm very interested in your IGN Maps!
 )Next year we should see some higher numbers after I upgraded the fuel system and can turn up the boost. Then with E85...
Alex
