Hi Heartland.
I got the 1UZ under the hood of my RA65 Celica, but I am running into a problem. I know you are right hand drive, and I am left hand drive, but I am curious if you ran into the same (other side) issue. The steering shaft coming out of the rack is running right into the exhaust manifold. I think we are going to have to cut up the manifold and re-weld it so the pipe exits higher up and further out to clear the steering shaft. The way it sits right now, we had to move the rack 3 inches to the left to hook it up and make it so we can push the car around and steer it, but it does not turn very sharp to the left as it is neer the end of travel, about 1 full turn left just to go straight. We can fix that with different length tie rods, but I don't want the resulting bump steer. I might be able to modify the rack a bit, but I think modding exhaust manifolds will be alot easier and safer. I would love to see a couple more pics of your swap. Especiall where the exhausts go from the heads to under the car.
Gary M.
Gary M.
