1997 toyota 1uzfe sc400
banshy2009
saudi arabia,riyadh
hi everyone
here is what i m doing in home shop and my project just to share some experiences all over the world as well some pictures of my project, the things is i m trying to test run my 1usfe sc400 97 which i bought recently, i would test run with no trans. on the floor in order to set it up for my sandrail later.hear are some pice regarding that and i will appreciate your coment and suggestion.
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-03180306_zpsf0b0ecc9.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-03181934_zps6315b500.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-03182758_zps18274739.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-04010820_zps2f37ae9c.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-04010856_zps1cd3eceb.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-14075807_zpscd783a3a.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-14075837_zps9f3b095b.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-13195041_zps7330b4b3.jpg
http://i816.photobucket.com/albums/zz86/banshee9090/2013-05-14075750_zps4742e6ca.jpg
in order to wire up and due to some wire harnesses cut and as per my research result in the net, either i should have correct 1uzfe sc400 97 control diagram map but so far i do not have it:D or to separate wire harnesses and trace the wires one by one:eek:
thanks
sorry guys i forgot to introduce myself , my name is Khalid i m from Saudi Arabia , 45 years old ,working as mechanical supervisor in one of the hospital in Riyadh, i have built ATV 10mil banshee drag engine so this is first time i play with four stroke engine,OK ,would back to my project again the photos tell what i have done recently
wiring up according to the tracing labeled, note and pinout diagram
http://i816.photobucket.com/albums/zz86/banshee9090/2013-06-01185013_zps9954ff56.jpg
thanks god come up with good result, but when i give it gas the motor stop, not rev. at max.
video-2013-05-31-20-01-45_zps0f5d7257.mp4.html
after search with mr.google i ground speed sensor and changed the ECU, again thanks god i come up with excellent result.
VID-20130601-WA0003_zpse7e4f517.mp4.html
