1995 LS400 mystery power loss
Bazzswann
Hello All
Got an issue with my UK 95 LS400 and been told that this is the place to get help!
Purchased a 95 LS400 a few months ago and all was well, however its developed a fault. So the car starts and drives fine as expected, but once it hits normal operating temperatures the EML comes on and car goes into "limp mode". Leave it to go "cold" and engine starts normal and drives fine until temperature is met. Added to this the dash lights keep coming on and dials have been randomly not working.
So took it to a local lexus indy and they have suggested and done the following:
Replaced Alternator
Replaced Lambda and O2 sensor
Replaced Temp Sensor
Still doing the same thing, in actual fact its got worse so goes into limp mode quicker. The indy has also said that there are no fault codes for the EML and or limp mode. Where do i go next? ECU replacement/refurb?
Any help would be much appreciated as the other half is getting to the stage of "i told you that buying an old car is a bad idea" stage :D
The EML constantly flashed when i used the ol wire trick but the garage has also said they dont get any fault codes on their scanner
A flashing / blinking CEL means there is a misfire in one or more cylinders - is your engine / wiring setup original to this car or has been swapped?
What I would do is drive it till it flashes again, dont turn the engine off, short te1 to groud to check codes and see what it comes up with
Plus, with a misfire - a simple spark plug inspection will also reveal which cylinder is not working
