Parts 1991 SC400 Soarer Limited Wrecking
converted
Hey guys,
I bought an SC400 limited for the engine ECU loom and bellhousing.
I am in the Seven Hills Sydney AUS region and Im prepared to take stuff off an mail/courier it at buyers cost. PM or ring me on 0400995409 for details.
parts available are as follows:-
  • A/C system complete or associated parts like copressor condesor evaporator etc
  • ABS unit
  • traction control system and actuators
  • Airbag suspension and actuators
  • front and rear windscreen
  • rear quarter windows (left and right)
  • rear suspension assembly (dunno if its LSD or ratio someone may shed light on whether this was a std item on the Limited Soarers)
  • tailshaft
  • transmission without bellhousing
  • digital instrument cluster
  • both doors without trim
  • fueltank
  • exhaust system
  • other item which I havent thought of you can contact me.
  • shell has australian compliance is damaged on front right chassis rail and right rear quarter. note the shell is not a stat write off which means it could be repaired and put on the road again.
  • I am prepared to sell the lot less the engine, loom, ECU and bellhousing.
regards,
Craig
look at the plate in the engine bay - read the axle code, and we'll tell you what the diff is :)
might be interested in rear subframe and suspension ams. dont need diff though. maybe also fron suspension arms
Do you have anything left?? chasing a passenger side interior door handle and the light bulb plug from the indicator and driving light in the front bar
