Hey all,
regarding a true 180 degrees exhaust system set-up
I've been sketching for a bit and came up with this solution, it should give the shortest possible runners and still be able to be fabricated quite neat.
problem is you need space, and as I'm planning mid engined that's quite easy!
anyway please look at the piccie.
I think I have made the right combinations on joining the exhaust pulses in to the collectors for aiding the scavaging effect. also the easiest routing of the headers can be done this way i think.
note that the collectors will be turned slightly (on a radius) so that the lowest 2 pipes will be the pipes entering from the opposite bank, that way you can run 4 pipes parralel inbetween the banks. (eerhm methinks)
does someone have something to add or improve to this?
Grtz Thomas
Grtz Thomas
