deankdx
- 489
- geelong, Victoria, Australia
Hi, i recently bought a 1992 LS400. runs fine, i did initially change the thermostat because it was running too cool, now sits just under half way as it should(from what i read)
the low level light doesn't come on(reservoir is topped up correctly)
there is a yellow light that flashes on at times next to the temp gauge that i assume should only be lit if the temp goes up to max?
is there 2 temp sensors? or is this light connected internally to the cluster temp gauge and has a fault?
