Hey guys,
I bought an SC400 limited for the engine ECU loom and bellhousing.
I am in the Seven Hills Sydney AUS region and Im prepared to take stuff off an mail/courier it at buyers cost. PM or ring me on 0400995409 for details.
parts available are as follows:-
Craig
- A/C system complete or associated parts like copressor condesor evaporator etc
- ABS unit
- traction control system and actuators
- Airbag suspension and actuators
- front and rear windscreen
- rear quarter windows (left and right)
- rear suspension assembly (dunno if its LSD or ratio someone may shed light on whether this was a std item on the Limited Soarers)
- tailshaft
- transmission without bellhousing
- digital instrument cluster
- both doors without trim
- fueltank
- exhaust system
- other item which I havent thought of you can contact me.
- shell has australian compliance is damaged on front right chassis rail and right rear quarter. note the shell is not a stat write off which means it could be repaired and put on the road again.
- I am prepared to sell the lot less the engine, loom, ECU and bellhousing.
Craig
