Smitherz
- 747
- Central Coast, CA
Sorry for the delay.... been a busy week here. The 1uz block isn't that heavy at all! Lifting it a couple of feet isn't a problem. Now with the heads installed two people will definitely be needed. I basically took the block down to what you see there and just replaced the crank seals without going any further. I have no need to remove the crank and pistons as the stock ones are quite capable of handling the power. If I did go through the bottom end it would end up costing me $1,200+ so I'll keep that money in my pocket for now. Maybe save it away for a couple turbos. :scratchchin:
I actually used an pneumatic right angle die grinder thing with a mild steel brush so do 90% of the cleaning/shining. The Dremel gets to the places that it won't. I'm writing up an article for Lextreme on how I cleaned everything. After the the second engine block I'm pretty damn quick at it. As for my cost on all the head, valve and manifold work... it was mostly a favor to me from a good friend so what I paid was nothing near the actual cost of the labor involved. I remember swearing at how many valves there were when I was changing out valve seals... I couldn't imagine the pain of actually doing all that custom work to every single valve and valve port!! His shop is the first one I'm visiting with my V8 Tacoma to show my appreciation of his support. Thanks for the compliments and I'll keep the updates coming as I move along... even if it's ever so slow.
