BimmerLex Pictures
Here is the drivers motor mount and trans mount. I made the motor mounts quick and even though its rock solid I might replace them with a better design at some point. I took the BMW motor mount arms and cut the center section out of one and the end section out of the other. I used the predrilled holes and bolted one side to the BMW motor mount and the other to the Alloy perch on the 1UZ. On the Trans, I slid one bolt (drivers side to rear) on the pre-existing BMW bolt track and I drilled through the hole that is about two inches in front of the back bolt. I dropped the bolt down through the floor board and used a nut on the bottom. I drilled the other two holes (3/8 drill bit) once I had these two tightened down and once I was convinced there was enough room to fit my radiator and electric fan set-up. The right side has to be spaced. I'm thinking I will use these very strong polyurethane bushings I have to conform to the floorboard for the spacers. I dropped two bolts through the passenger floorboard and used nuts on them too. This is all just in the rough and I change my mind a lot so It may actually be different when I'm finished. Any one out there made progress on the their E30 projects?
