Error Code P1354 is defined as Variable Valve Timing System Malfunction Bank 2
I have replaced the bank 2 VVT Solenoid twice now, yet the code continues to come back. I replaced the wiring and the harness connector is a tight fit. I'm at a loss, two separate mechanics tell me the solution is another solenoid. Searching throughout forums all I can find for P1354 is to replace the solenoid. But it's been replaced twice so far.
any ideas for what else to look at? This is the only code on the engine, but it also turns on the VSC OFF light.
I can clear the code and run the car for 50+ miles without issue only to have it come on again
