After completing my engine swap (97 1UZ into a 98 4Runner), the motor started right up but was misfiring badly. It seemed to smooth out at higher RPM's but shakes violently under light load (around 1200-1500 RPM). I was finally able pull the codes and came up with this:
P0300 - Random/Multiple Cylinder Misfire Detected
P0305 - Misfire Detected, Cylinder 5
P0307 - Misfire Detected, Cylinder 7
My friend and I did a little troubleshooting but kept getting the same misfires in # 5 and #7. Here's what we did:
-Checked continuity & resistance to #5 & #7 plug wires. Both checked OK.
-Inspected both spark plugs. Looked normal, but when compared to a known good cylinder (#3), they looked much cleaner.
-Swapped plugs with #3 and #5 to verify issue was not with faulty a plug. Checked good...no misfire in #3.
-Connected a test light to the #5 plug wire and started the car. It indicated good spark.
-Did a similar test with the #7 side, but put in a spark plug in place of the light. It also was visibly sparking correctly.
-Checked & cleaned injector electrical connectors.
I wish it were a simple matter of changing out some old components. But while I had this motor on a stand, I changed the caps, rotors, plugs, wires, etc. Everything was replaced with new. The plugs are Denso Iridium and can't exactly be gapped, but they looked the same when compared to a known good plug. Also, when I did the timing belt & tensioner, I triple checked to make sure I had it aligned properly. Plus, I think if it were off, there would be a few more misfires or problems?
After doing all this, we were pretty certain the ignition side of things was ok - the distributors were supplying power to the spark plugs. Not to mention, if something was up with a coil, distributor, or ignitor, it would manifest itself on #1/7/6/4 or #2/8/3/5, not 5 and 7...right?
We looked into the cylinder and saw it was a little wet. Not an obvious head gasket leak, but more like unburnt fuel. Both suspect plugs looked like they were working, and the presence of unburnt fuel made me believe the injectors were working as well. I had all the injectors cleaned and flow tested a while ago but hit them with a squirt of carb cleaner before installation to clean off the preservation oil.
I still need to do a compression check and maybe inspect the caps & rotors again, but have I missed something incredibly obvious? Anyone got any pointers?
