92 1UZFE LS400 Engine plugs part #'s
Bollox
This is a long shot, I'm building a new harness for my project and all the connector plugs are as dry and brittle as a popcorn fart. Would anyone by chance have a list of part numbers for all of the engine plugs?
  1. Crank sensor
  2. Cam Sensors same L & R
  3. Ignitors plugs (2) plus pins
  4. Injector connectors
  5. Knock sensors (2)
  6. Coil pack connectors (2)
  7. AFM
  8. Oil Pressure switch
  9. ICS connector
  10. TPS connector
  11. OEM ECU connector pins and plugs
I dont know the part numbers but have some of those in stock. Crank , LH cam , Injectors , Knock(two options I have one), Coil , Oil pressure , ISC and TPS. I have the second series of gen 1 ecu main 28 pin plug as thats all I need when wiring stock harness and the earlier ECU 26 pin plug (same as VVti which I wire heaps of).
I rebuilt a loom the other day with as many new plugs as I could.
That's a long way to send the connectors, I think they are made in the USA, well some of them at least, but I would like to ask you how much to ship them to me,
Also, I have a crank sensor, do you have the wiring for that, I think I have the pins round the wrong way,
My injector plugs are Japanese, Real deal Nippon denso , I also have copies. Ill take some photos and get some pricing.
Hi mate, when you talk about the 28 pin plug are you referring to the 4th plug on the ecu?
Yes thats the one. The 28 pin plug on the ECU. Does depend on the ECU you have as 92 is the year they change ECU pin counts.
