good to see alot of work being done by owner, instead of paying someone.
how much plenum volume did the custom one have? also shorter runners the custom would have more up top, unsure why it didn't work must have had some serious issues. usually you can throw anything on and it will work.
we use the factory lower with custom plenum, might be costing us 50-80hp, but, it works fine engine is showing 1200hp with a couple old 62mm cast wheel turbo's, and was under $1000 to do. we will be doing a full custom intake manifold later, will be a good lil design with much smaller plenum volume, currently has 8-9L. new one 3.6-4L should be plenty.
 Yes Justen, the fifth gear of the R154 is weak... Obviously...
