how much would it cost to have a duplicate of this made? and also could it be made to use the stock throttle body?
Been away for a while.
Now if the I/cooler had vertical tubes and a tank top and bottom there will be another 50rwhp!
Erol
Can't read Steve? vertical core ICs are generally the go where you can fit them....better flow path and x-sectional area. You need the runner length to make sure you get the cooling but if there's enough height, this style of IC is the better option..
Won't make it flow better Ryan
Not that it's doing a bad job.
The extra hp RMS refers to will come from the extra flow from the vertical core....the cooling won't be much different.
Still, WI is a good thing. I thought Millis had that already?
Yea well mainly it helps keep detonation at bay ..
try again
