Wanted Wanted Round Alternator Connector & loom
ivan129
BlownZX
Hi Everyone, I've just sourced another alternator and have plans to swap it with the one fitted to my 1UZFE. The new alternator uses a three pin round connector that has spade female connectors inside it whereas the old one uses a three pin in line connector. I would realy like to track down a round connector with a short piece (say 100mm) of loom. If you have a round three pin alternator connector you can do without please drop me a pm. Loacted in Rowville, Melbourne. Thanks... Regards Ivan :)
just goto yr local auto elect and they should be able to supply
the adaptor to go from one to the other. no soldering needed
I've got about 15 round plugs but doubt any will have 100 mm
length
Round alternator connector
Thanks Sideshow... So I assume its some sort of generic connector? I'll give a couple of the local auto-elecs a try here but if they can't help me then I will conatact you for a price to supply one, if thats ok.
Regards Ivan
length
yes the oval plug is pretty much all late toyota
the round plug is pretty much all old toyota
ive seen the adpaters afew times so they are available
Thanks
Picked one up today from the local auto-elec. Thanks again..
Regards Ivan
