Hey all.
So after going down a dragstrip with too much timing I have 2 cyls with low compression. I think its either the rings or the lands. I'm definately losing pressure into the crank case and it smoke quite a bit if I push it at all. I bought a used motor to build since the car still runs ok. The motor was SUPPOSED to be a 92 but turns out its a 95. From what I can tell it DOES have the THICK rods however. I have not actually pulled out a piston / rod yet to confirm but have measured the small end thickness as best as possible with the short block intact.
I actually have had the motor for about a week now. Have it torn down to the bare short block at the moment short of removing the oil pump and rear main seal retainer. Have hot washed the heads, upper intake, lower intake, valve covers, oil pans, ect....
I am struggling with the idea of getting some pistons for it. I don't think I will get rods since I'm pretty sure I have the thick ones. I've been eyeing the Ross 99733 pistons (google it). Any advice would be great here. I am also considering just pulling out the pistons, honing the bores and installing new rings. If I get pistons it will be off to the machine shop.
I have ported the lower intake to match the gaskets. I intend to port the upper intake as well to match the gaskets. I have ported one head to match the intake gaskets and intend to do the other. Will probably at least polish the exhaust side. I have installed 8 small water meth nozzles to the lower intake. Should be interesting. I intend to flip the upper intake and valve cover gaskets to get the throttle body closer to the supercharger.
I intend to get rid of the IAC valve and use a Bosch 3 wire valve. This is mostly to free up some outputs from the Adaptronic. Also going back to using a bypass valve.
I am going to replace EVERY seal on the motor. Already have most of them. Have a set of Cometic HGs on the way, standard thickness. Have removed the valves and intend to clean and "lap" them. This thing will be pretty much brand new by the time I'm done with it.
I'm not sure if I'm going to use the wiring harness that came with the purchased motor. I'd like to since the engine has to be about half way torn down to get it out. I'd like to have the motor as ready to put in as possible before removing the engine currently in the car. But there are a ton of broken connectors on it and I'd have to do some re-wiring on it to make it work with my setup. Not really a huge deal but time consuming.
Theres some more bits but thats the most of it I think.
Right now I'm just struggling with what I want to do as far as actual upgrades. As said, I'm really considering pistons. Would be a wise investment. I've been talking with a machine shop who seems confident that they good handle the job. Also looking at cams and valve springs. Also looking at aftermarket throttle bodies.
I don't need it to handle 1000hp but I would like to never have to do all this again.
Let me know what you all think. I'll try and take some pictures soon.
Thanks,
KC
 From what I can tell it DOES have the THICK rods however. I have not actually pulled out a piston / rod yet to confirm but have measured the small end thickness as best as possible with the short block intact.I actually have had the motor for about a week now. Have it torn down to the bare short block at the moment short of removing the oil pump and rear main seal retainer. Have hot washed the heads, upper intake, lower intake, valve covers, oil pans, ect....
Thanks,
KC
	 Advice welcome......
 ... More boost
... More boost
