Boost and engine airflow calculators
I had a play...the supercharger Vol eff is very significant in determining the resulting boost and small changes mean big differences in results. The simple one on the Soarer website is a better bet....i've used it twice now to calc the SC pulley size and both times it's been within a psi.
link please?
Whatever works best for you.
That said there is a field for supercharger volumetric efficiency on the calculator I referenced (VEsc =) line 10
Was there a problem you noticed?
that was my point...get this input wrong and your answer is rubbish. eg. in the example show he quoted an SC eff of 0.9!! damn high, even for turbo. most are more like 0.5...which will then give nearly half the boost.
the simple table on the soarer site, regardless of how they calc'd them, seems to give a good real world number for a UZ with a roots SC.
just a comment
just a comment
I would think volumetric efficiency of 90% would be believable. Even the older 3 lobe 5th gen Eaton 112 listed at Magnuson Products hits that at 10psi and slightly higher at 5psi.
http://www.magnusonproducts.com/images/mp112g1.jpg
The 6th generation 4 lobe TVS units have much better inlet to airspeed so they do even better with numbers approaching perfect.
The source for the below image with much more data
http://www.smokinvette.com/corvette/articles/eaton-tvs-supercharger/
Now, if we are talking adiabatic efficiency then 90% isn't going to happen more in th 60-70% range. Old roots would be in the 50%.
