chin
- 3
- Atlanta, GA USA
First off I want to say hello and thank you. This forums helped me to track down a intermittent connection at the fuse box, that was preventing ignition to reach my ECU. That is now resolved but...
I can get the car to run perfectly by bypassing the fuel pump ecu. I picked up 2 junkyard fuel pump ecu's the other day and neither one of them work. I just want to be absolutely certain the fuel pump ecu is/isn't the problem. With no bypass and the fuel pump ecu plugged in normally, car will just crank and no start. I can supply power directly to the fuel pump at the diagnostic connector or at the fuel pump ecu and hear the fuel pump run and car will start fine. Power is going into the fuel pump ecu via the heavier gauge black w/ red stripe, but no power leaving the fuel pump ecu from the heavier gauge green wire. Am I over thinking this? What's the chances of getting 2 bad fuel pump ecu's?
Would a crank or cam sensor prevent the fuel pump ecu from energizing the fuel pump? Thank you.
