rwdfreak
- 67
- Montreal, Canada
Sorry if it as arleady been posted, but couldn't get anything out of the search button.
I've got a question for the guy using Howe trow out bearing. Mine is pn.82870.
I made my own adapter using the 1UZ bell. My questions are mostly concerning oil feeding and bleeding and proper instalation:
First: I figured the correct thread on the bearing is 7/16-20 UNF standard on 1/4" Tube. The problem is I couldn't find any good fitting to be able to fit to the M10x1.0 tread for 3/16" Tube that Toyota use and that is already on the car. How did you guys solved the tubing issues?
Second: How did you do to keep the bearing from turning? According to Howe you normaly put a threaded pin in the transmission and it just stop when it touch on one side or the other of the Y made by the oil supply fitting. However it is not something rigid that can garantee it won't move between the Y and put stress on the oil lines.
Third: Those who used many spacers to make the bearing reach the transmission did you had any issues since you need a hell lot of them to rest on the tranny and since they are small and not thight on the shaft they could move and make noises?
Mostly my question is how the hell did you made everything fit properly together? Any inputs will be greatly appreciated.
Thanks
For the one not used to what the Howe TO bearing look like.
Thanks
