Replacing rear engine seal
34ford
Looking for info on how to replace the rear engine seal on a 1UZ crown. If someone knows how, i can add pics to the txt and add to lextreme.
Ditto to the above...
good tips too add is to use a matching sized punch to install the seal and add a light amount of grease to the seal's inner lip where it hits the crank.
Mick,
Don't froget to use either new factory flywheel bolts or use a goodly amount of Loctite on the old bolts.
The flange on the crankshaft is drilled right through and oil can work its way up the thread if it is't sealed completely.
