Wanted WTD - 2x 90º speedo drives
Pro
Hi all,
chasing two 90deg speedo adaptor drive thingos off the A340-1 transmissions, but if you only have one then - hey great - i'll take that too.
need them asap shipped to Parmelia WA 6167.
will pay a reasonable price.
cheers.
what do u mean 90 degree
i have afew speedo sensors of soarers and crown 1uzs
they are all electric sensors
do you need an actual 90 degree adpater for a speedo cable
i dont have any 90 degree fittings
can probably order one
is this because there is no room for the speedo cable to come straight out of the box and it will hit the tunnel or the gbox crossmember
does your gbox have an electronic sensor at moemnt or is it cable and you just need the 90 degree bit
or is it electronic and you need the whole cable speedo drive with the 90bit
what car did the gbox come out of
if its a crown u can unscrew the electric speedo sensor part of the speedo drive
but if its any other 1uz gbox the electric sensor and drive is all one unit
so depending what you need could cost anything over 300 bucks
i need just the 90º bit that comes out of the crown box - my speedo cable wont bolt up to the box because tunnel is RIGHT on it.
don;t need any electronic anything.
whassit gonna cost?
Been to a wrecker?
Almost every RWD Toyota from the 80's will have these.
I have 2 broken ones at home.
every wrecker i talk to has no idea what i'm talking about.
i think this forum or pick-a-part is my only option.
Random.
I have at least one at home, but definitely needs repairing (cable has snapped).
You are welcome to have it and get it repaired. (I get home on Thursday)
Both my MX73 Cressida, and all the MA61 Supra's I've seen have had them from factory.
thanks for that - i'll check out pick a part for those models.
would prob cost more to have it repaired than to get a s/h one.
cheers.
