Wiring Diagram for Toyota 1UZ-FE
mic123
I have fitted a 1UZ-FE to a race car, the car is ready to run but i need wiring diagram showing pin out numbers for the ECU, It says on the label:
Toyota 89661 - 30430
26p 16p 22p
1UZ-FE
I believe the ECU is from a crown but can find no info. Any info on the subject will be helpful.
Cheers, Mike
PM me your email address and I'll send you a detailed write up on wiring the Crown engine.
Am still looking for pin out info for engine control systems for crown ecu model number: 89661-30430. 26p 16p 22p being the configuration. can anyone help? have tried to open other files but they have had errors still need info
Edbv,
You've done well to find those schematics.
Kdog (an early 1UZ Guru) did those in around 2003-4 and I haven't seen them for years.
I do have a hard copy.
I can still supply a write up on wiring the Crown ECU without auto.
Neither. MREL is an output from the ecu. I can supply proper instructions for a price. I wire a couple of these engines each week atm. Cheers.
