-Nemesis-
I'm finally fitting a fan bracket on my engine to run a proper serpentine belt, previously I had simply deleted the hydraulic set up and as such have been getting belt slip.
Anyways, my engine bay is extremely tight, my best cooling system yet is reliant on the big shrouded twin thermo's I have. But there's now a catch, the clearance is that tight the front knob on the fan bracket is going to prevent me re-fitting the fans!!!
So a quick question if anyone knows the inside of these: What will I uncover if I grind back the assembly to roughly where the red line is here? Is there a bearing that far forward?
		 ) so if I can clamp it in enough that should slice the face off nicely.
