What pressure plate lbs??
Mattmannz
I am due to replace my clutch and the old one had been slipping a bit due to the pressure plate being a bit light.
What lb's are most people running? Stock Hilux's run about 1400, it would seem that about 2000 would be the go. How much extra effort does this place on the clutch leg?
Matt.
When I first setup my car the pressure plate that came with the CRS bellhousing kit was 550kg and it slipped badly in 3rd gear with WOT.
I replaced it with a 950kg unit and it grabs really well. My wife finds the pedal slightly heavy but totally drivable.
Regards,
Matt.
Im using a mazda plate resprung to 1200kg for the racecar on a recommendation. havent tried it yet, but the recommendation should be a good one.
