Wow, there is a whole science behind all of this....Thanks for the explanation Peewee and Toys.......
However, similar to what 1uzvl had stated, when my car previously had ran at cooler temps before reaching it's normal operating temp it always seemed to run stronger, more responsive, etc.. ...That is why I figured a slightly lower and maintained operating temp would boost power, reduce engine wear, etc... That theory is incorrect as the stock ECU changes fuel/air ratio's as the engine heats....That is my understanding to this point...
Thermal expansion......So as the engine heats to factory settings the internal parts move easier with less gaps due to the heat expansion, etc...Parts are then made to move easier which actually causes less wear and increases performance..
I had always thought colder is better to some degree....I now see there is a fine line with all of that...To cold no good, too hot no good...
Does cast iron pistons and engine blocks really expand with heat? Very interesting.....I had thought that to be true with an alluminum block and other softer metals?
