Hi,
I am building a 1UZFE powered Hilux and am in the process of plumbing and connecting everything at the moment.
I can't figure out what a thing is on the front (to the right of center at the belt end of the motor). It says on it "Valve Hydraulic Control" and has a 2 pin connector plug for electrics to it.
Also in the same area are two pipes that look like they had oil in them? Are these related to the above valve? If so where do I plumb them to?
I believe the motor is from a 1999 Soarer, so possibly it is all for VVTi? If it is for the VVTi then do I need to use it? (I am running it with a Link ECU) Or will it run ok without??
Hope I'm not asking stupid questions??
Cheers,
Graeme
Cheers,
Graeme
