using alot of fuel
hilux_bondy_007
hey guys, i have just put a temp gauge and found out i am runnign at 80 degress.
i also am having a problems.
1. car stalls when i a decellerating and drop from 3 to 2second, and seems to be a over fueling problem.
2. car seems to be running at roughly 20l per 100km. i dont have a air box only a soarer airbox but its opened up. would that be a factor and the fact that its runnin around 75 to 80 degress??
if anyone has any help can u please let me no.
Umm been there. You'll find it's stuck in "cold start", choke on if you will causing it to overfuel. You need it to run around 88 degrees so check you fan setting (or does it operate full time like mine).
But firstly check to see if it has logged any DTCs then check the basics eg thermostat stuck open etc
