Two Different Throttle Bodies
SC400TT
Hey gang:
Sine I am installing stand alone engine and transmission management in my project car, I am eliminating all emissions and EGR. I will also not neede the TRAC traction control system form Lexus. I have never seen the non-traction control throttle body, but I believe it only has 1 butterfly. Should I jusr remove the secondary butterfly in mine, or should I locate a non-TRAC TB to install in its place?
Thanks,
Ryan
Actually guys, I am wondering if you know much about the TRAC system on the Lexus...Is it run from a separate module from the stock ECU? The SM4 does not do Traction control, the SM2 does, and I did not know this until tonight. So, if I can get the TRAC to stil work without the stock ECU, then that would be optimal. Your input is most appreciated here.
Ryan
We just remove the butterfly and weld the holes up - The non traction control throttle body is the same length and the standard one can be sorted easily - cheers
