I have to build a rear mount sump with the shallowest possible front section for clearance over the crossmember/steering rack. What is the minimum clearance I can get away with between the crankshaft and the sump? The pickup tube will need to run down the side to the rear pan and the standard tube is 1" dia.
Also after ideas for windage trays, louvered or mesh screen, and crank scrapers...
