Just call me "Lex"
- 12,033
- City of Halos
As you guys might noticed already or will notice. The Lexus V8 starter is located between the two heads under the lower intake. This design save space but a nightmare for mechanic or at least DIY guys like us. Not too long ago I had the honor to change one and it was a handful and took about 5 hours for the job. Not only its time consuming but also require special tool to remove the starter.
Now I have an oppertunity to install a new engine in the near future and decided to alter the mounting position to reduce future nightmare if I have to change the starter. What I did was to get two 1/2"-1" longer then stock 10 mm along with the matching nuts. Instead of screwing the bolts from the rear of the engine. I got two fully threaded 10 mm going from the front to rear. If I have to remove the starter again, I don't have to unscrew the bolts from the rear. The two nuts behind the engine will be welded to the block so it won't move when tightened. Its pretty simple mod but surely solve lots of time in the future if removing the starter is require.
I double check using a socket removing the 10 mm from the front is not a problem at all. Here are some pictures:
