Sc430 abs delete
Uklowranger
could anyone tell me if the abs is completely removed from a 2002 sc430 Will the automatic transmission still function correctly.
I can't imagine why the ABS would be linked to the transmission.
I've removed ABS from a few cars and they still drive OK.
Why not pull the ABS fuse and go for a drive?
Thanks for your reply Zuffen.
I’m not a mechanic or electrical engineer but have done lots of internet reading and thought the modern automatic gearbox’s ecu received a signal from abs ecu. I have also read that the LS400 has a second signal to the speedometer which is sufficient to run gearbox alone, is this true for the LS430,(there was a reasonable sc430 but it is sold now)
The reason for my questions is I am wanting to use mostly everything from a donor vehicle except the axles, diff, brakes for a custom truck and here in the UK LS400’s are getting scarce and commanding bigger price tags than 430’s.
Thanks, Kev.
You can put 2002 sc430 engine , transmission and ecu into anything and once wired properly it will work properly. Stock ABS is not required.
