SC400 Rings?
pogoism9
So I noticed that as far as the SC400 goes, there are ring sets for 92-95, 96, 97, and 98-2000. What are the differences between the 92 rings and the 96 rings? Are they interchangeable?
1996 is a series-2 engine with 10HP increase and a 10.4:1 compression increase. You'll probably find different pistons in there.
Here's the thread from Club Lexus on year-to-year changes.
http://www.clublexus.com/forums/sc-...he-sc300-400-and-feature-changes-by-year.html
Lextreme has a thread showing rod changes between different engine series. The heavier-duty rods from the first series 1UZ seem to justify the claim they can "just" be setup for forced induction.
Lextreme Rod Thread:
http://www.lextreme.com/Toyota-Lexus-Rods.html
Cheers!
1994 Sc400
Check the size ?? It could be just different engineered ring as in bevel on inside top rings [for example]to aid ring seal..
While earlier models may not have this feature ??
Check with what fits your pistons / bore. I assume std bore ??
Btw it "COULD" be a blown head gasket ??
Have you done a leak down test ?? Compression test.. ???
