SC400 Light replacement? Help!
YZFR1
I have never felt this useless in my life.... I just bought my SC400..... Overall the car is in incredible shape....... But a few of the MISC. BS stuff needs to be done....... Tail light bulb............Fog Light bulb...... Parking light bulb...... And, well...... I feel slightly helpless as it is entirely different than i've ever before seen... I didn't look too much on the Tail light, but i would guess i have to remove the whole thing and fo course, its on the right side with the key for the trunk lock. Ok, the Fog light bulb......... It is just an H3...... How the hell do you get the fog light removed to gain access to this?
Please Help.... : )
Dan
Pull the trunk liner out to reveal the back of the tail lights.
The front ones I don't think you have to pull anything.. just find your way to the back of them to unscrew them. Fog light, probably try going in from underneath..?
Headlights are a pain. Just have to unbolt whatever is in the way and then jam your hand in there.
TO TAKE OUT YOUR HEAD LIGHTS THERE IS A BOLT ON TOP OF THE LIGHT YOU SHOULD SEE IT WHEN U POP YOUR HOOD, THERE ARE 2 MORE BEHIND THE WHEEL TAKE OFF THE 5 BOLTS IN THE WHEEL WELL THAT SUPPORT THE PLASTIC SHELD BEND THAT BACK AND WHERE THE BLINKER SHOULD BE THERE ARE 2 10MM BOLTS, TAKE OFF THOSE AND THE PULL THE HEADLIGHT OFF FROM THE BUMPER SHOULD COME RIGHT OFF, I HAVE DONE THIS ABOUT 100 TIMES AND IF YOUR HEAD LIGHT LOOKS YELLOW I CAN FIX THAT AS WELL I ALSO CAN MAKE THE CROME BLACK LOOKS COOL IF YOU LIKE THE SPORT LOOK, CAN SPRAY THEM IN ANY COLOR AS WELL, LOOKS LIKE THIS
http://clearcorners.com/products/lexus/sc1/
JUST WITHOUT THE LEDS INSIDE, CAN DO THE LEDS BUT IF THEY BURN OUT YOU HAVE TO DO A LONG FIXING. I WONT CHARGE 2G'S AS WELL MORE LIKE 250.00 AND U PAY FOR SHIP
[email protected]
