Pretty much. If you want to get it at a better spot on the map, you've got to either get the mass flow up or the PR down. Unfortunately you're right at the speed limit of the supercharger, so you don't have much you do to play around with that. VE% improvements can help, but only go so far. All and all your dyno graph looks very driveable, but could certainly be improved.
The big problem is that within the Rotrex product line there isn't a great match for your current setup and power goals. The reason I mentioned porting is that the big chunk taken out of the surge side of the map can be somewhat alleviated by compressor shroud porting. I'd have to do a layout to tell you where to put it and dimensioning and all that. Unfortunately, that's basically impossible without a bunch of drawings (or unless someone does a complete inspection/measurement on the parts), so that's why I only mentioned it in passing.
-Kirk
-Kirk
