chodjinn_mk2
Hi, I'm looking to swap out the push on breather fittings on each rocker cover to AN10 fittings (either weld on or screw/o-ring type) and was just wondering, is it possible to remove the baffle plates inside the rocker covers?  I was just going to cut off the push-on fittings and drill to the right size, but I'm worried about getting swarf inside the baffle plates and not being able to remove it.
They look to be press-fit with little studs so I'd rather get some advice before messing around with them, what have other people done?
Thanks in advance
Thanks in advance
