- 5,632
- Sydney, Australia
UTA,
My engine is in a Range Rover and I have around 6" additional under bonnet clearance.
You can fit both M90 and M112 under the bonnet by using either a Rush Imports manifold (I hear Neil doesn't sell them to the States) or one from Joel (Jordyskiboat.) Both gents are on this Forum. With these manifolds I don't think you would fit an intercooler under the bonnet.
I'm using the MP112 of a Lightning.
I started fitting mine yesterday and I'm using the Lightning supercharger, interccoler and manifold.
So far I've cut the manifold down so it fits in the valley of the engine (I had to remove the knock sensors, starter and heater pipe). I need to relieve a little from the area beside the ports on the head so the manifold will sit in the bottom of the valley.
Once I have the manifold sitting as low as I can get it I'll probably send it to Joel so he can do the machining required to fit my manifold to it.
Fitting the system doesn't look too hard or complicated but having to re-locate the starter makes this conversion only acceptable for cars with lots of ground clearance as the starter is now under the engine.
The attached photo shows the system sitting on the engine. I expect it to drop by another 3". You'll notice the intercooler imediately below the supercharger. This unit is 2" high and will stop you getting it all under your bonnet. Also you'll see the supercharger has the wrong bolt pattern for the intercooler. This is a spare unit I have.
The second shot is a side view of the intercoler. You can see how it hangs down into the valley.
